This topic contains C# code snippet that shows how to get information about thumbnail image (filename and page index) in the thumbnail viewer.
using System;
using System.Text;
using System.Windows.Forms;
using Vintasoft.Imaging;
using Vintasoft.Imaging.UI;
namespace WindowsFormsApplication1
    /// Main form.
    public partial class MainForm : Form
        /// Initializes a new instance of the <see cref="MainForm"/> class.
        public MainForm()
            InitializeComponent();
            thumbnailViewer1.FocusedIndexChanged +=
                new EventHandler<FocusedIndexChangedEventArgs>(thumbnailViewer1_FocusedIndexChanged);
        /// Clears image collection of thumbnail viewer and
        /// adds image(s) to an image collection of thumbnail viewer.
        private void openButton_Click(object sender, EventArgs e)
            if (openFileDialog1.ShowDialog() == DialogResult.OK)
                thumbnailViewer1.Images.ClearAndDisposeItems();
                foreach (string fileName in openFileDialog1.FileNames)
                        thumbnailViewer1.Images.Add(fileName);
                    catch (Exception exc)
                        MessageBox.Show(exc.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
        /// Focused image is changed.
        private void thumbnailViewer1_FocusedIndexChanged(object sender, FocusedIndexChangedEventArgs e)
            ThumbnailViewer viewer = (ThumbnailViewer)sender;
            VintasoftImage image = null;
            if (e.FocusedIndex != -1)
                image = viewer.Images[e.FocusedIndex];
            ShowImageInfo(image);
        /// Shows the image information.
        /// <param name="image">The image.</param>
        private void ShowImageInfo(VintasoftImage image)
            if (image == null)
                imageInfoTextBox.Text = string.Empty;
                ImageSourceInfo sourceInfo = image.SourceInfo;
                StringBuilder builder = new StringBuilder();
                builder.AppendFormat("File: {0}", sourceInfo.Filename);
                builder.AppendLine();
                if (sourceInfo.PageCount > 1)
                    builder.AppendFormat("Page: {0}/{1}", sourceInfo.PageIndex + 1, sourceInfo.PageCount);
                imageInfoTextBox.Text = builder.ToString();
        /// Raises the Closed event.
        protected override void OnClosed(EventArgs e)
            base.OnClosed(e);
Source codes of WinForms application for VintaSoft Imaging .NET SDK 14.0 can be downloaded here.
