This topic contains C# code sample that shows how to convert an extra large PDF page to a TIFF image:
namespace ConvertLargePdfToTiffConsoleApp
    /// This example shows how to convert PDF page of unlimited size to a TIFF file.<br />
    /// Size of PDF page is not limited because image renderer divides PDF page into tiles and
    /// process each tile separately.<br />
    /// Size of TIFF image is not limited because TIFF encoder divides TIFF image into tiles and
    class Program
                // create an image collection
                using (Vintasoft.Imaging.ImageCollection images = new Vintasoft.Imaging.ImageCollection())
                    // add PDF document to the image collection
                    images.Add("documentWithLargePage.pdf");
                    // set the rendering resolution for PDF document
                    images.SetRenderingSettings(new Vintasoft.Imaging.Codecs.Decoders.RenderingSettings(new Vintasoft.Imaging.Resolution(300, 300)));
                    // create TIFF encoder
                    using (Vintasoft.Imaging.Codecs.Encoders.TiffEncoder tiffEncoder = new Vintasoft.Imaging.Codecs.Encoders.TiffEncoder())
                        // specify that TIFF encoder must create tiles in TIFF file - this prevents loading the whole PDF image into memory
                        tiffEncoder.Settings.UseTiles = true;
                        // specify the TIFF tile size
                        tiffEncoder.Settings.TileSize = new System.Drawing.Size(2048, 2048);
                        // specify that TIFF encoder must detect the image compression automatically
                        tiffEncoder.Settings.Compression = Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffCompression.Auto;
                        // subscribe to the image saving progress
                        images.ImageSavingProgress += Images_ImageSavingProgress;
                        // save images to TIFF file
                        images.SaveSync("output.tif", tiffEncoder);
                    // clear image collection and dispose images
                    images.ClearAndDisposeItems();
                    System.Console.WriteLine("File is converted successfully.");
            catch (System.Exception ex)
                System.Console.WriteLine(string.Format("Error: {0}", ex.Message));
            System.Console.WriteLine("Press any key...");
            System.Console.ReadKey();
        private static void Images_ImageSavingProgress(object sender, Vintasoft.Imaging.ProgressEventArgs e)
            // print information about image saving progress
            System.Console.Write(string.Format("{0} ", e.Progress));
VintaSoft Imaging .NET SDK (Standard) (Vintasoft.Imaging.dll) and VintaSoft PDF .NET Plug-in (Reader) (Vintasoft.Imaging.Pdf.dll) are necessary for executing this sample.
