/// Writes the GPS tags into existing TIFF file.
/// <param name="filePath">The file path.</param>
/// <param name="pageIndex">Index of the page.</param>
private static void WriteGpsTags(string filePath, int pageIndex)
using (TiffFile tiffFile = new TiffFile(filePath))
// get the page
TiffPage page = tiffFile.Pages[pageIndex];
// find existing GPS image file directory tag
TiffTag gpsIfdTag = page.IFD.Tags.Find(TiffTagId.GpsIFD);
// GPS image file directory
TiffImageFileDirectory gpsIfd;
// if file doesn't have GPS metadata
if (gpsIfdTag == null)
// create GPS image file directory
gpsIfd = new TiffImageFileDirectory();
// add necessary tags
TiffTagCollection gpsTags = gpsIfd.Tags;
gpsTags.Add((ushort)GpsTagId.GPSVersionID, new byte[] { 3, 2, 0, 0 });
gpsTags.Add((ushort)GpsTagId.GPSLatitudeRef, "N");
gpsTags.Add((ushort)GpsTagId.GPSLatitude, GetLatitudeOrLongitude(34.385090));
gpsTags.Add((ushort)GpsTagId.GPSLongitudeRef, "W");
gpsTags.Add((ushort)GpsTagId.GPSLongitude, GetLatitudeOrLongitude(118.940933));
gpsTags.Add((ushort)GpsTagId.GPSAltitudeRef, (byte)0);
gpsTags.Add((ushort)GpsTagId.GPSAltitude, new TiffRational(14838, 100));
gpsTags.Add((ushort)GpsTagId.GPSMapDatum, "WGS-84");
// add GPS image file directory
page.IFD.Tags.Add(TiffTagId.GpsIFD, gpsIfd);
gpsIfd = (TiffImageFileDirectory)gpsIfdTag.Data;
// set data of existing tags and add missing tags the same way as above
tiffFile.SaveChanges();
/// Gets the specified latitude or longitude value in degrees
/// as corresponding TIFF tag data.
/// <param name="degrees">The value of latitude or longitude value degrees.</param>
/// <returns>
/// An array of TIFF RATIONAL containing encoded value,
/// rounded off to whole seconds.
/// </returns>
private static TiffRational[] GetLatitudeOrLongitude(double degrees)
TiffRational[] result = new TiffRational[3];
double wholeDegrees = Math.Floor(degrees);
result[0] = new TiffRational((uint)wholeDegrees, 1);
double remainingMinutes = (degrees - wholeDegrees) * 60;
double wholeMinutes = Math.Floor(remainingMinutes);
result[1] = new TiffRational((uint)wholeMinutes, 1);
double remainingSeconds = (remainingMinutes - wholeMinutes) * 60;
double wholeSeconds = Math.Floor(remainingSeconds);
result[2] = new TiffRational((uint)wholeSeconds, 1);
return result;
Source codes of console application for VintaSoft Imaging .NET SDK 14.0 can be downloaded here.
