Code samples
Code samples for VintaSoft Annotation .NET Plug-in. Here you can request a code sample.
Board index < VintaSoft Imaging < VintaSoft Annotation .NET Plug-in Discussions < Code samples
WPF: Build rectangle annotation with specified size when user clicked on image.
Here is C# example for WPF that shows how to add a rectangle annotation with size 100x100 on image when user clicked on image.
/// User started the annotation building.
private void buildAnnotationButton_Click(object sender, RoutedEventArgs e)
        // create annotation view
        WpfAnnotationView annotationView = new WpfRectangleAnnotationView(new RectangleAnnotationData());
        if (annotationView != null)
            // subscribe from the Interaction event of annotation builder
            annotationView.Builder.Interaction += Builder_Interaction;
            // start annotation building
            Viewer.AnnotationVisualTool.AddAndBuildAnnotation(annotationView);
    catch (InvalidOperationException ex)
        MessageBox.Show(ex.Message, "Building annotation", MessageBoxButton.OK, MessageBoxImage.Error);
/// Handles the Interaction event of the annotation builder.
void Builder_Interaction(
    object sender,
    Vintasoft.Imaging.Wpf.UI.VisualTools.UserInteraction.WpfInteractionEventArgs e)
    // desired annotation width and height
    double annoWidth = 100;
    double annoHeight = 100;
    // change the start and end location of interaction - this is necessary for correct Location and Size of annotation
    e.StartLocation = e.Location;
    e.Location = new System.Windows.Point(e.Location.X + annoWidth, e.Location.Y + annoHeight);
    // specify that interaction is finished
    e.InteractionFinished = true;
    WpfAnnotationViewer annotationViewer = (WpfAnnotationViewer)e.Viewer;
    WpfAnnotationView annotationView = annotationViewer.FocusedAnnotationView;
    // unsubscribe from the Interaction event of annotation builder
    annotationView.Builder.Interaction -= Builder_Interaction;
    // set annotation parameters (Location and Size will be set by builder)
    annotationView.CanResize = false;
