- Coordinates of left-top corner of rectangle
- Size of rectangle
- Rotation angle of rectangle
- Coordinates of center of rectangle annotation
- Size of rectangle annotation
- Rotation angle of rectangle annotation
Here is C# example for WPF that shows how to create not rotated rectangle annotation if rectangle on image is specified using coordinates of left-top corner of rectangle and rectangle size:
/// Creates not rotated rectangle annotation.
/// <param name="rectLeftTop">The left top coordinates of rectangle.</param>
/// <param name="rectSize">Size of rectangle.</param>
/// <returns>Not rotated rectangle annotation.</returns>
private WpfRectangleAnnotationView CreateNotRotatedRectangleAnnotationView(
System.Windows.Point rectLeftTop,
System.Windows.Size rectSize)
// center of not rotated rectangle
System.Windows.Point rectCenter = new System.Windows.Point(rectLeftTop.X + rectSize.Width / 2, rectLeftTop.Y + rectSize.Height / 2);
// create rectangle annotation
RectangleAnnotationData rectAnnoData = new RectangleAnnotationData();
WpfRectangleAnnotationView rectAnnoView = new WpfRectangleAnnotationView(rectAnnoData);
// specify annotation location as center of rotated rectangle
rectAnnoView.Location = rectCenter;
// specify annotation size
rectAnnoView.Size = rectSize;
// return the rectangle annotation
return rectAnnoView;
Here is C# example for WPF that shows how to create rotated rectangle annotation if rectangle on image is specified using coordinates of left-top corner of rectangle, rectangle size and rotation angle of rectangle:
/// Creates rotated rectangle annotation.
/// <param name="rectRotation">Rotation angle, in degrees, of rectangle.</param>
/// <returns>Rotated rectangle annotation.</returns>
private WpfRectangleAnnotationView CreateRotatedRectangleAnnotationView(
System.Windows.Size rectSize,
double rectRotation)
System.Windows.Point rectCenter = new System.Windows.Point(rectSize.Width / 2, rectSize.Height / 2);
// create Matrix
System.Windows.Media.Matrix matrix = new System.Windows.Media.Matrix();
// rotate Matrix
matrix.Rotate(rectRotation);
// translate Matrix
matrix.Translate(rectLeftTop.X, rectLeftTop.Y);
// transform center of not rotated rectangle using Matrix AND get center of rotated rectangle
rectCenter = matrix.Transform(rectCenter);
// specify annotation rotation
rectAnnoView.Rotation = (float)rectRotation;
