Hello Yuri,
I have installed the VintaSoft Simple barcode Writer Demo v8.1. There, in the GUI are a few controls that are not clear to me. I hope you can help me.
1. В»Min bar/cell widthВ« and В»Width...В«, both placed in one line, side by side.
Does the term "cell" in В»Min bar/cell widthВ« refer to the SPACE BETWEEN the BARS of the barcode?
2. В»Width...В« [set Width in px/"/cm/mm + Resolution in DPI] does it set the BAR-width or the BARCODE-width?
When I increase В»Min bar/cell widthВ«, still the number entered in В»Width...В« stays the same, when it should get auto-adjusted... I am probably wrong, but how do these two controls interact with each other?
3. BarsWidthAdjustment Property ="Width adjust (x0.1)"-Spinner/numeric_updown in the GUI???
I found some info here, not being sure if it is the fitting info:
https://www.vintasoft.com/docs/vsbarcode ... tment.html
"Gets or sets the adjustment method of bars width in percentage to the value of MinWidth property."
Is this what the Spinner/numeric_updown in the GUI does?
Best regards
Nico
