This topic contains code sample that shows how to create new visual tool that allows to drag-and-drop image region between different image viewers.
Here is source codes of visual tool (AdvancedDragAndDropTool.cs file):
using System;
using System.Drawing;
using System.Windows.Forms;
using Vintasoft.Imaging;
using Vintasoft.Imaging.ImageProcessing;
using Vintasoft.Imaging.UI;
using Vintasoft.Imaging.UI.VisualTools;
using Vintasoft.Imaging.UI.VisualTools.UserInteraction;
namespace VintasoftDragDrop
/// Visual tool that allows to drag image region and drop it to the same or different image viewer.
public class AdvancedDragAndDropTool : RectangularSelectionTool
#region Constants
/// The drag and drop effect of current visual tool.
DragDropEffects DRAG_DROP_EFFECT = DragDropEffects.Copy | DragDropEffects.Move;
#endregion
#region Fields
/// The cursor location on image.
PointF _dragPointInImageSpace = PointF.Empty;
/// The size of dragging image.
RectangleF _draggingImageSize = RectangleF.Empty;
/// Visual tool where drag-and-drop process is started.
AdvancedDragAndDropTool _sourceTool = null;
#endregion
#region Constructors
/// Initializes a new instance of the <see cref="AdvancedDragAndDropTool"/> class.
public AdvancedDragAndDropTool()
: base()
AdvancedDragAndDropToolTransformer advancedDragAndDropToolTransformer = new AdvancedDragAndDropToolTransformer(this);
advancedDragAndDropToolTransformer.DraggingStarted += new EventHandler(advancedDragAndDropToolTransformer_DraggingStarted);
TransformController = advancedDragAndDropToolTransformer;
#endregion
#region Properties
/// Gets the name of the visual tool.
public override string Name
get
return "Image Drag And Drop Tool";
bool _isDragging = false;
/// Gets a value indicating whether the image is dragging.
public bool IsDragging
get
return _isDragging;
#endregion
#region Methods
#region PUBLIC
/// Draws the visual tool on specified System.Drawing.Graphics.
/// <param name="viewer">An image viewer.</param>
/// <param name="g">A graphics where this tool must be drawn.</param>
public override void Draw(ImageViewer viewer, Graphics g)
if (_isDragging)
if (viewer.Image == null)
return;
// draw image
Rectangle rectInControl = Rectangle.Round(viewer.RectangleToControl(GetDrawingBoxInImageSpace(viewer, _sourceTool)));
using (VintasoftImage draggingImage = _sourceTool.GetDraggingImage())
if (draggingImage == null)
return;
draggingImage.Draw(g, rectInControl);
// draw border
g.DrawRectangle(Pens.Red, rectInControl);
base.Draw(viewer, g);
#endregion
#region PROTECTED
/// Raises the <see cref="VisualTool.Activated"/> event.
/// <param name="e">An <see cref="EventArgs"/> that contains the event data.</param>
protected override void OnActivated(EventArgs e)
base.OnActivated(e);
this.ImageViewer.AllowDrop = true;
this.ImageViewer.DragEnter += new DragEventHandler(imageViewer_DragEnter);
this.ImageViewer.DragLeave += new EventHandler(ImageViewer_DragLeave);
this.ImageViewer.DragOver += new DragEventHandler(imageViewer_DragOver);
this.ImageViewer.DragDrop += new DragEventHandler(imageViewer_DragDrop);
/// Raises the <see cref="VisualTool.Deactivated"/> event.
protected override void OnDeactivated(EventArgs e)
base.OnDeactivated(e);
this.ImageViewer.AllowDrop = false;
this.ImageViewer.DragEnter -= new DragEventHandler(imageViewer_DragEnter);
this.ImageViewer.DragLeave -= new EventHandler(ImageViewer_DragLeave);
this.ImageViewer.DragOver -= new DragEventHandler(imageViewer_DragOver);
this.ImageViewer.DragDrop -= new DragEventHandler(imageViewer_DragDrop);
#endregion
#region PRIVATE
/// Handles the DraggingStarted event of the advancedDragAndDropToolTransformer control.
/// <param name="sender">The source of the event.</param>
/// <param name="e">The <see cref="EventArgs"/> instance containing the event data.</param>
private void advancedDragAndDropToolTransformer_DraggingStarted(object sender, EventArgs e)
// get location of drag point
_dragPointInImageSpace = GetCursorPositionInImageSpace(ImageViewer);
// get size of dragging image
_draggingImageSize = GetDrawingBox(ImageViewer);
_sourceTool = this;
// start new interaction (dragging and dropping)
DragDropEffects effects = this.ImageViewer.DoDragDrop(this, DragDropEffects.Move);
/// Handles the DragEnter event of the imageViewer control.
/// <param name="e">The <see cref="DragEventArgs"/> instance containing the event data.</param>
private void imageViewer_DragEnter(object sender, DragEventArgs e)
if (ImageViewer.Image != null)
_sourceTool = (AdvancedDragAndDropTool)e.Data.GetData(typeof(AdvancedDragAndDropTool));
if (_sourceTool != null)
_isDragging = true;
e.Effect = DRAG_DROP_EFFECT;
/// Handles the DragLeave event of the ImageViewer control.
private void ImageViewer_DragLeave(object sender, EventArgs e)
Rectangle = Rectangle.Empty;
InvalidateViewer();
/// Handles the DragOver event of the imageViewer control.
private void imageViewer_DragOver(object sender, DragEventArgs e)
if (e.Data.GetDataPresent(typeof(AdvancedDragAndDropTool)) &&
e.Effect == (DRAG_DROP_EFFECT))
Rectangle = GetDrawingBoxInImageSpace(ImageViewer, _sourceTool);
/// Handles the DragDrop event of the imageViewer control.
private void imageViewer_DragDrop(object sender, DragEventArgs e)
Rectangle droppingRectInImageSpace = GetDrawingBoxInImageSpace(ImageViewer, _sourceTool);
if (droppingRectInImageSpace.IsEmpty)
return;
return;
int offsetX = 0;
int offsetY = 0;
if (droppingRectInImageSpace.X < 0)
offsetX = -droppingRectInImageSpace.X;
droppingRectInImageSpace.X = 0;
if (droppingRectInImageSpace.Y < 0)
offsetY = -droppingRectInImageSpace.Y;
droppingRectInImageSpace.Y = 0;
if (offsetX != 0 || offsetY != 0)
draggingImage.Crop(new Rectangle(offsetX, offsetY, draggingImage.Width - offsetX, draggingImage.Height - offsetY));
OverlayCommand overlayCommand = new OverlayCommand(draggingImage, Point.Round(droppingRectInImageSpace.Location));
overlayCommand.ExecuteInPlace(ImageViewer.Image);
InvalidateViewer();
/// Calculates drawing box in image space.
/// <param name="viewer">Image viewer.</param>
/// <param name="tool">Current visual tool.</param>
/// <param name="mouseLocationInScreen">Mouse position in screen coordinates.</param>
private Rectangle GetDrawingBoxInImageSpace(ImageViewer viewer, AdvancedDragAndDropTool tool)
return Rectangle.Empty;
int offsetXInControl = (int)Math.Round(tool._dragPointInImageSpace.X - tool._draggingImageSize.X);
int offsetYInControl = (int)Math.Round(tool._dragPointInImageSpace.Y - tool._draggingImageSize.Y);
Point mousePositionInImage = GetCursorPositionInImageSpace(viewer);
return new Rectangle(
mousePositionInImage.X - offsetXInControl,
mousePositionInImage.Y - offsetYInControl,
(int)Math.Round(tool._draggingImageSize.Width),
(int)Math.Round(tool._draggingImageSize.Height));
/// Gets position of the cursor in image space.
private Point GetCursorPositionInImageSpace(ImageViewer viewer)
Point mouseLocationInClient = viewer.FindForm().PointToClient(Cursor.Position);
Point mouseLocationInControl = new Point(mouseLocationInClient.X - viewer.Location.X,
mouseLocationInClient.Y - viewer.Location.Y);
return viewer.PointToImage(mouseLocationInControl);
/// Gets the image region that should be dragged.
private VintasoftImage GetDraggingImage()
VintasoftImage img = ImageViewer.Image;
if (img.IsProcessing)
this.TryFinishInteraction();
return null;
Rectangle imageRect = new Rectangle(0, 0, img.Width, img.Height);
Rectangle drawingBox = Rectangle.Round(_draggingImageSize);
drawingBox.Intersect(imageRect);
CropCommand cropCommand = new CropCommand(drawingBox);
return cropCommand.Execute(img);
#endregion
#endregion
Here is source codes of transformer of visual tool (AdvancedDragAndDropToolTransformer.cs file):
/// An interactive transformer that allows to select image region in image viewer and
/// starts drag-and-drop operation when image region is moved.
private class AdvancedDragAndDropToolTransformer : RectangularObjectTransformer
#region Fields
/// Drag-and-drop visual tool.
AdvancedDragAndDropTool _tool = null;
#endregion
/// Initializes a new instance of the <see cref="AdvancedDragAndDropToolTransformer"/> class.
/// <param name="interactiveObject">An interative object.</param>
internal AdvancedDragAndDropToolTransformer(IRectangularInteractiveObject interactiveObject)
: base(interactiveObject)
if (interactiveObject is AdvancedDragAndDropTool)
_tool = (AdvancedDragAndDropTool)interactiveObject;
#endregion
#region Properties
/// Gets a value indicating whether controller is visible.
public override bool IsVisible
get
if (_tool != null)
return !_tool.IsDragging;
return true;
#endregion
#region Methods
/// Performs an interaction between user and interaction area of interactive object.
/// <param name="args">An interaction event args.</param>
protected override void PerformInteraction(InteractionEventArgs args)
// if visual tool interacts with selection
if (args.Area == MoveArea)
switch (args.Action)
// if selection is moving
case InteractionAreaAction.Move:
OnDraggingStarted();
return;
// if interaction with selection is canceled
case InteractionAreaAction.Cancel:
args.InteractionFinished = true;
return;
base.PerformInteraction(args);
/// Raises the <see cref="AdvancedDragAndDropToolTransformer.DraggingStarted"/> event.
private void OnDraggingStarted()
if (DraggingStarted != null)
DraggingStarted(this, EventArgs.Empty);
#endregion
#region Events
/// Occurs when dragging is started.
public event EventHandler DraggingStarted;
#endregion
And here is sources codes of a form with 2 image viewers (Form1.cs file):
using System;
public partial class Form1 : Form
public Form1()
InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
imageViewer1.SizeMode = Vintasoft.Imaging.UI.ImageSizeMode.BestFit;
imageViewer1.Image = new VintasoftImage("apple.jpg");
imageViewer1.VisualTool = new AdvancedDragAndDropTool();
imageViewer2.SizeMode = Vintasoft.Imaging.UI.ImageSizeMode.BestFit;
imageViewer2.Image = new VintasoftImage("apple.jpg");
imageViewer2.VisualTool = new AdvancedDragAndDropTool();
You can combine work of the AdvancedDragAndDropTool and AnnotationDragAndDropTool (https://forums.vintasoft.com/viewtopic.php?f=24&t=2255) classes if you need drag-and-drop an image region or annotation from one image viewer to another.
Here is a code snippet that shows how to do this:
imageViewer1.VisualTool = new CompositeVisualTool(
imageViewer1.AnnotationVisualTool,
new AnnotationDragAndDropTool(),
new AdvancedDragAndDropTool());
imageViewer2.VisualTool = new CompositeVisualTool(
imageViewer2.AnnotationVisualTool,
