Remove refences to version 6 assemblies from your application.
Add references to version 8.0 assemblies to your application.
Try to compile your application - you will have errors.
Analyze the errors and create a list of classes which are not found. Class may be not found because it was deleted, it was renamed or it was moved to another namespace. Information about changes in version can be found in the "Changes history":
