Image acquiring
Image acquiring
Post by malovern »
I am running into a problem scanning duplex images where occasionally, the images are being saved with one page of one image and one of another scanned image (these are scanned on a Canon dr6010c in batches)
My ImageAcquired code is below with the barcode processing in a separate thread. My question is, when duplex is enabled, are images always sent in the exact order they are scanned?
This is a head scratcher for me
Any help appreciated,
Kind Regards
Jim
private void onDevice_ImageAcquired(object sender, ImageAcquiredEventArgs e)
        Device _device = (Device)sender;
        // image acquisition must be cancelled because application's form is closing
        if (cancelTransferBecauseFormIsClosing)
            // cancel image acquisition
            _device.CancelTransfer();
            return;
        pageCount++;
        if (imageFileName == string.Empty)
            imageFileName = generateNewFilename();
        AcquiredImage acquiredImage = _device.AcquiredImage;
        if (_device.DocumentFeeder.DuplexEnabled)
            if (!imageFileName.Contains("Y"))
                imageFileName += "Y.tif";
            acquiredImage.Save(
               Path.Combine(currentScanStation.ScanFolder,
               imageFileName));
            //If the page count is 2 then the next image (if any) will be a new file to save
            if (pageCount == 2)
                imageFileName = string.Empty;
                pageCount = 0;
                currentStationScannedCount++;
        else //Not a duplex scan
            imageFileName += "N.tif";
            acquiredImage.Save(
               imageFileName));
            pageCount = 0;
    catch (Exception ex)
        MessageBox.Show("Failed to save image : " + ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
    finally
        updateDGVStations(currentScanStation, 1, currentStationScannedCount);
        Application.DoEvents();
Re: Image acquiring
Hi Jim,
Your code looks correct. I think your scanner can discard blank pages and your application does not receive blank pages. Am I right?
Re: Image acquiring
Post by malovern »
Currently, the application does receive blank pages - testing here on my dr 4010c - I believe its the same behaviour on the 6010c. So I receive two pages per scan regardless of whether one side is blank when duplex is enabled.
I am wondering if the processing thread is trying to process the images before the image is properly saved. To this end, I have made some changes to scan the images into another folder then move them into a processing folder. This way, this ensures the files are written correctly prior to being checked for barcodes. I have also added code to set the acquiredImage class to disposed after each scan to ensure that the image being saved is the current one, hopefully this resolves it ;)
From my limited testing, it does appear that the scanner (and thus Vintasoft) does send the images in the order they are scanned.
Kind Regards
Jim
Re: Image acquiring
Hi Jim,
I am wondering if the processing thread is trying to process the images before the image is properly saved. Your application processes acquired image in background thread. Am I right? If yes, you need examine your code for logical mistake.
Please let me know if you will have any question or problem.
