sample to read text content in pdf
Post by marco.malizia »
Hi
I need to read (in VB.NET application) TEXT CONTENT from a particular page and AREA from pdf files.
I try with this sample (below) but don't function (don't function well).
I have problem to know exact coordinates, i try with sample PdfReaderDemo, but the coordinates and resolutions do not corresponding well.
Any suggestions? Any way to suggest for reading text from a particular AREA form pdf?
Thanks.
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Dim x1 As Int16, x2 As Int16, y1 As Int16, y2 As Int16
    Dim vTesto As String = ""
    Dim vArea As SizeF
    Dim vRect As RectangleF
    Try
        _fileStream = New FileStream(edPdf1.Text, FileMode.Open, FileAccess.Read)
        _document = PdfDocumentController.OpenDocument(_fileStream)
        vTesto = _document.Pages(0).TextRegion.TextContent
        edTxt1.Text = vTesto
        vArea = _document.Pages(0).GetPageSizeInPixels(_document.Pages(0).DefaultResolution)
        x1 = Convert.ToInt16(edX1.Text)
        x2 = Convert.ToInt16(edX2.Text)
        y1 = Convert.ToInt16(edY1.Text)
        y2 = Convert.ToInt16(edY2.Text)
        If x1 <> 0 Or x2 <> 0 Or y1 <> 0 Or y2 <> 0 Then
            vRect = New RectangleF(x1, y1, x2, y2)
             vTesto = _document.Pages(0).TextRegion.GetSubregion(vRect).TextContent
    Catch ex As Exception
    End Try
Re: sample to read text content in pdf
You have 2 logical mistakes in your code.
First, you need convert coordinates from the image space to the page space before getting of text content.
Next, you need specify width and height of rectangle as third and fourth parameter in the RectangleF constructor.
Here is correct code:
Dim points As Single() = {x1, x2, y1, y2}
_document.Pages(0).PointsToUnits(points, _document.Pages(0).DefaultResolution)
x1 = points(0)
x2 = points(1)
y1 = points(2)
y2 = points(3)
    vRect = New RectangleF(x1, y1, x2 - x1, y2 - y1)
