It is not looks like bad synchronization in my code. Are Vintasoft BarcodeReader isntances thread safe? If no, which best practices of instantiation you can recommend to use? How much is costs to create and dispose BarcodeReader instance in each worker routine? Did this class uses unmanaged code and structures?
void Recognize()
BarcodeReader reader = new BarcodeReader();
_setupReader(reader);
var files =
Directory.EnumerateFiles(_baseDirectory, "*.jpg");
Parallel.ForEach(
files,
(file) =>
var result = reader.ReadBarcodes(file);
lock (recognitionPages) // recognitionPages is just a System.Collections.Generic.Dictionary<string, IBarcodeInfo[]>
recognizedPages[file] = result;
static void _setupReader(BarcodeReader reader)
reader.Settings.ScanDirection =
ScanDirection.Vertical |
ScanDirection.Horizontal;
reader.Settings.ScanBarcodeTypes =
BarcodeType.Code39 |
BarcodeType.Code128;
reader.Settings.ExpectedBarcodes = 2;
