We are testing your "VintaSoftPDF.NET SDK" & "VintaSoftImaging.NET SDK" to get the following:
Explore each word in the text of PDF file for to know his position (X,Y,width and height -rounding box-)
If we have next portion of code:
Private imageViewer1 As Vintasoft.Imaging.ImageViewer
Private _fileStream As System.IO.Stream = Nothing
Private _document As Vintasoft.Pdf.PdfDocument
Private _useEmbeddedThumbnails As Boolean = True
Private _titlePrefix As String = "VintaSoft PDF Reader Demo v3.1 {0}"
Private _isFirstOpenedPage As Boolean = False
_fileStream = New System.IO.FileStream(strArchivoPDF, System.IO.FileMode.Open, System.IO.FileAccess.Read)
_document = Vintasoft.Pdf.PdfDocumentController.OpenDocument(_fileStream)
_document.RenderingSettings.DrawPdfAnnotations = True
_document.RenderingSettings.DrawVintasoftAnnotations = True
_document.RenderingSettings.UseEmbeddedThumbnails = _useEmbeddedThumbnails
_fileStream.Position = 0
Dim openFileThread As New System.Threading.Thread(AddressOf OpenFileAsynchronously)
openFileThread.Start()
_isFirstOpenedPage = True
Text = String.Format(_titlePrefix, String.Format("- {0}", System.IO.Path.GetFileName(strArchivoPDF)))
If _document.IsEncrypted Then
Text += " (SECURED)"
' Let's go to generate JPG's...
firstPage = 1
lastPage = _document.Pages.Count
For pageNo = 1 To _document.Pages.Count
strNombreArchivoJPG = "PAG_" & Format(pageNo, "000") & ".jpg"
MsgBox(_document.Pages(pageNo).TextRegion.TextContent)
'we need to explore the position of each word in the text
Next
We have been reviewing the help, not just find a way to do this easily with TextRegion, Subregion, LineSubregion, GetWordSubRegion ???We don't understand who it works...
Can you help us ?
Thanks.
