Version 5.0 of VintaSoftTwain ActiveX has been released.
What's new in this version:
  • ActiveX is compatible with TWAIN 2.0 now.
  • Added ability to detect if TWAIN is installed in the system.
  • Added ability to specify path to TWAIN Data Source Manager. This feature allows to use library in Citrix systems.
  • Added ability to detect if scanner has flatbed.
  • All properties begin with the upper letter now. C++ code which uses library must be updated.
  • DuplexEnabled property has been optimized for compatibility with Epson GT 2500 scanner.
  • New GetPathToTempDir method allows to save acquired image in web applications for preview.
  • New ConvertArrayToString method allows to work with COM arrays in JavaScript.
  • New GetImageLayoutAsString method allows to get the layout of scanning image in JavaScript.
  • Now you can create log-file and send it to our support team if scanner does not work properly.
  • Some major and minor fixes.
  • Examples have been updated.
