Forum 'VintaSoft Barcode .NET SDK Discussions'
Image extraction from pdf (BarCode reader 6.1.2.1)
Post by paolozan »
Good day.
I'm trying to detect a barcode inside a pdf (1.5 version) document.
In the code fragment below, the call GetImageNames give me the exception: "Object is not found" and "Data = {System.Collections.ListDictionaryInternal}".
What's wrong ?
Thank you.
  Pdf = new Vintasoft.Barcode.PdfImageViewer(NomeFile);
catch(Exception Ecc)
  Errore = Ecc.Message;
  Pdf.Dispose();
  Pdf = null;
  return null;
if (Pdf.PageCount == 0)
  Pdf.Dispose();
  Pdf = null;
  return null;
string [] TmpNomiImmagini;
  TmpNomiImmagini = Pdf.GetImageNames(0);
  Pdf.Dispose();
  Pdf = null;
  return null;
if (TmpNomiImmagini.Length == 0)
  Pdf.Dispose();
  Pdf = null;
  return null;
Re: Image extraction from pdf (BarCode reader 6.1.2.1)
Could you send us your PDF document for tests?
If yes, please send your file to support@vintasoft.com
