set area to scan
set area to scan
Post by quicoli »
Hi friends!
I'm trying to set area size for scanning, just like demos does, but I'm getting a full page scan. What can be wrong?
 _device.PixelType = PixelType.BW;
 _device.BitDepth = 1;
 _device.Resolution = new Resolution(200, 200, UnitOfMeasure.Pixels);
 _device.ShowIndicators = false;
 var l1 = _device.ImageLayout.Get();
 _device.ImageLayout.Set(0, 0, l1.Width, l1.Height/2);
And here is my scanner properties
Fabricante: Hewlett-Packard
FamГ­lia de produto: All-in-One
Nome do produto: HP Photosmart C4700 TWAIN
VersГЈo do drive TWAIN: 1.9
CompatГ­vel com TWAIN 2.0: False
Mesa de alimentaГ§ГЈo presente: True
Alimentador automГЎtico presente: False
Recurso: Id=1, Name=XferCount
Modo: Get, Set, GetDefault, Reset
Valor atual: -1
Recurso: Id=256, Name=ICompression
Modo: Get, GetDefault
Valor atual: None
Valores suportados: None Jpeg Lzw
Recurso: Id=257, Name=IPixelType
Valor atual: RGB
Valores suportados: BW Gray RGB Palette
Recurso: Id=258, Name=IUnits
Valor atual: Inches
Valores suportados: Inches Centimeters Points Pixels
Recurso: Id=259, Name=IXferMech
Valor atual: Memory
Valores suportados: Native Memory File
Recurso: Id=4098, Name=FeederEnabled
Valor atual: False
Recurso: Id=4101, Name=SupportedCaps
Modo: Get
Valores suportados: SupportedCaps UIControllable XferCount IBitDepth IBitOrder ICompression IImageFileFormat IPhysicalWidth IPhysicalHeight IPixelFlavor IPixelType IPlanarChunky IUnits IXferMech IXResolution IYResolution IXScaling IYScaling DeviceOnline Indicators EnableDsUiOnly IThreshold AutoFeed FeederEnabled FeederLoaded IGamma Duplex DuplexEnabled IBrightness IContrast PaperDetectable IAutoBright IBitDepthReduction
Recurso: Id=4103, Name=AutoFeed
Modo: Get
Valor atual: True
Recurso: Id=4107, Name=Indicators
Valor atual: True
Recurso: Id=4109, Name=PaperDetectable
Valor atual: True
Recurso: Id=4110, Name=UIControllable
Modo: Get
Valor atual: True
Recurso: Id=4111, Name=DeviceOnline
Modo: Get
Valor atual: True
Recurso: Id=4115, Name=DuplexEnabled
Valor atual: False
Recurso: Id=4116, Name=EnableDsUiOnly
Valor atual: False
Recurso: Id=4352, Name=IAutoBright
Valor atual: False
Recurso: Id=4353, Name=IBrightness
Valor atual: 0
Valor padrГЈo: 0
Recurso: Id=4355, Name=IContrast
Valor atual: 0
Valor padrГЈo: 0
Recurso: Id=4360, Name=IGamma
Valor atual: 2,199997
Recurso: Id=4364, Name=IImageFileFormat
Valor atual: Bmp
Valores suportados: Tiff Bmp Jpeg
Recurso: Id=4369, Name=IPhysicalWidth
Modo: Get
Valor atual: 8,5
Recurso: Id=4370, Name=IPhysicalHeight
Modo: Get
Valor atual: 11,68999
Recurso: Id=4376, Name=IXResolution
Valor atual: 200
Valor padrГЈo: 200
Recurso: Id=4377, Name=IYResolution
Valor atual: 200
Valor padrГЈo: 200
Recurso: Id=4380, Name=IBitOrder
Valor atual: 1
Valor padrГЈo: 1
Valores suportados: 0 1
Recurso: Id=4383, Name=IPixelFlavor
Valor atual: Chocolate
Valores suportados: Chocolate Vanilla
Recurso: Id=4384, Name=IPlanarChunky
Valor atual: 0
Valor padrГЈo: 0
Recurso: Id=4387, Name=IThreshold
Valor atual: 0
Valor padrГЈo: 0
Recurso: Id=4388, Name=IXScaling
Valor atual: 1
Valor padrГЈo: 1
Valores suportados: 0,09999084 0,1999817 0,2999725 0,3999634 0,4999542 0,5999451 0,6999359 0,7999268 0,8999176 0,9999084 1,099899 1,19989 1,299881 1,399872 1,499863 1,599854 1,699844 1,799835 1,899826 1,999817 2,099808 2,199799 2,299789 2,39978 2,499771 2,599762 2,699753 2,799744 2,899734 2,999725 3,099716 3,199707 3,299698 3,399689 3,49968 3,59967 3,699661 3,799652 3,899643 3,999634 4,099625 4,199615 4,299606 4,399597 4,499588 4,599579 4,69957 4,799561 4,899551 4,999542 5,099533 5,199524 5,299515 5,399506 5,499496 5,599487 5,699478 5,799469 5,89946 5,999451 6
Recurso: Id=4389, Name=IYScaling
Valor atual: 1
Valor padrГЈo: 1
Recurso: Id=4395, Name=IBitDepth
Valor atual: 8
Valor padrГЈo: 8
Valores suportados: 1 8 16
Recurso: Id=4396, Name=IBitDepthReduction
Valor atual: Threshold
Valores suportados: Threshold Halftones
Re: set area to scan
I think you set a wrong resolution value. Are you sure you need set the resolution in pixels?
Please try to use this code:
_device.UnitOfMeasure = UnitOfMeasure.Inches;
_device.Resolution = new Resolution(200, 200, UnitOfMeasure.Inches);
Post by quicoli »
Friend Alex,
I did as you said, but it didnt work :(
Maybe my scanner driver is not compatible?
My scanner is not only a scanner, it is a scanner + printer model.
thanks
Unfortunately, most of TWAIN drivers for HP's multi-functional devices do not allow to set the image layout.
Try to use WIA driver of your device.
