Set the AnnotationViewer's Current Image
Post by Junhui »
Hello, Alex. I have a problem with AnnotationViewer.
I got the image files from DB, and maked them to VintasoftImages, and added to annotationViewer's ImageCollection.
My Codes are below,
foreach(...)
VintasoftImage img = new VintasoftImage(mstream);
annotationViewer1.Images.Add(img);
After that, I inserted image file to annotationViewer's ImageCollection.
My Codes are below,
VintasoftImage img = new VintasoftImage(_sourceStream);
annotationViewer1.Images.Insert(0, img); //not add(), want to insert at the top.
When I run my code, _sourceStream image inserted ordinarily at the top of my AnnotatedThumbnailViewer.
But annotationViewer1's image doesn't change to the inserted image.
I want to change image not only AnnotatedThumbnailViewer but also AnnotationViewer when I inserted image.
I tried these codes below but they didn't work.
annotationViewer1.FocusedIndex = 0;
or...
annotationViewer1.Refresh();
or...
annotationViewer1.Images[0].SetImage(new VintasoftImage(_sourceStream));
they all didn't work properly.
I want your some advice to handle this problem.
Best Regards,
Jun-Hee.
Re: Set the AnnotationViewer's Current Image
Post by Junhui »
I know when I use Add(), can change current image of annotationViewer1's image properly.
Like codes below,
annotationViewer1.Images.Add(_sourceStream);
annotationViewer1.FocusedIndex = annotationViewer1.Images.Count - 1;
But I want to "Insert" image at the top of the annotatedThumbnailViewer,
so I inserted image at ImageCollection's 0 index.
They didn't work properly.(annotationViewer's image doesn't change) So I need your some advice.
Best Regard,
Jun-Hee.
Hello Jun-Hee,
Thank you for your message and good description of the problem, we have fixed the problem in version 5.0.5.1 of VintaSoftImaging.NET SDK.
