Can I install on a 64-bit OS?
Post by iansml »
I am trying to install a test application on 32 and 64-bit operating systems. It works perfectly on all 32-bit systems tested so far, but I can't get the Twain dll to work on the only 64-bit OS I have available (Windows Server 2008). The error message I'm getting is:
An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B) The stacktrace indicates that this is thrown when Vintasoft.Twain.VSTwain.StartDevice() is called.
Have you tried this dll on 64-bit OS's? Is there a workaround or a plan to support 64-bit in the future?
Ian
Re: Can I install on a 64-bit OS?
Post by iansml »
This may not be a problem after all. I've tried a solution and it seems to have helped get past this initial error.
Will test further to see if there are any other "64-bit" problems.
Ian
Hi Ian,
When an application that uses VintaSoftTwain.NET Library is compiled on a 64-bit system you may run into a couple issues. Our assembly is 32-bit assembly; therefore any applications being compiled on a 64-bit system must run in the 32-bit bit (WOW) mode. This only requires changing the "Platform Target" setting on the Build tab of your project settings to x86. Without this setting you will receive a BadImageFormatException when running your application.
Native 64-bit mode is not supported at the moment.
Post by htaylor »
I also run 64bit for my development platform. I have set the target platform to x86 and my program will now run but when I open my scanning form and hit my scan button I am asked to select a device and after I do that my scan form closes and my scanner's scan prompt window opens. I hit scan and it does a preview then freezes I wonder if this is because it expects my scanning form to be there Why is it closing
My Main application window is still present in the background. If I click on it and Exit my application the scan prompt window then closes. Any ideas about what is going on here? I am using a Epson Perfection V700 scanner, Vista Ultimate, 64bit, 6gb RAM, VS2008, Framework v3.5
This is close to working and I hope it does. This product seems to be exactly what I need and the price is good.
Post by htaylor »
I did get this working but I had to incorporate the code from the ''Complex'' sample which is WAY too much GUI for the expertise of my user base so I am going to have to go through this and figure out what I can disable/hide/delete to get this to a manageable level for my users.
That said I am pleased and will buy a license.
When I get this to a more user-friendly state I will add an email address to this post so people who need a user-friendly form/GUI can request the code.
Elvis has left the building :D
Hello Taylor?
Do you think that our Advanced demo is too difficult? :-)
