Forum 'VintaSoft Twain ActiveX Discussions'
Board index < VintaSoft Twain < VintaSoft Twain ActiveX Discussions
Save to PDF
Save to PDF
Post by ositalia »
I would like to know if, with ActiveX, you can save acquired (multiple) images to a PDF file instead of multipage tiff.
Regards
Re: Save to PDF
VintaSoftTwain ActiveX does not support saving of images to PDF documents.
Re: Save to PDF
Post by mvsenin »
Please give a look at this post - https://forums.vintasoft.com/viewtopic.php?f=17&t=659#p2806.
Main idea is as follows:
- store as much separate images as you need,
- then use Apache FOP to compile a PDF containing all the images (FOP only needs an XSL tagged document, very similar to an HTML or XML)
