Hardware and Vendors Discussions
Details and opinions about specific devices, drivers, and scanner vendors.
Board index < VintaSoft Twain < Hardware and Vendors Discussions
Plustek image scanners.
Here is a list of Plustek image scanners (http://www.plustek.com/) tested with our products by us or our customers:
  • Plustek OptiCard 820
  • Plustek OptiCard 821
  • Plustek OpticPro A360
  • Plustek SmartOffice PS286 Plus
  • Plustek SmartOffice PS406U
  • Plustek SmartOffice PS456U
We can recommend Plustek image scanners for usage with our products.
If you have tested other Plustek simage canner with our product and want to share your experience, please post it here. Thank you in advance.
Re: Plustek scanners.
Some TWAIN drivers for Plustek scanners, for example, version 5.2.0.0 of TWAIN driver for Windows 8.1 for Plustek PS286 Plus (http://plustek.com/uk/products/smart-of ... s286-plus/), have critical bug - driver can be used only by the application, which filename (without extension) has 15 symbols or less. For example, driver will work with your application if your application has filename "123456789012345.exe" (filename length is 15 symbols) but driver will raise an exception if your application has filename "1234567890123456.exe" (filename length is 16 symbols).
Hope, Plustek will fix bug in their drivers in near time.
Re: Plustek image scanners.
Plustek OpticPro A380 Plus image scanner (TWAIN API) has been successfully tested by our customer.
