Incorrect image colors
Post by luca78mi »
I am evaluating the demo version (7.0.27.1) with a Canon MX870, Win7 32 bit, Visual Studio 2010, VB dot net 4.0.
When i acquire using BW or Gray pixeltype, everything works correctly.
The main problem occurs when i set RGB. The resulting image is almost blue as you can see in this picture.
If i do the same job with other softwares (like Twack_32.exe) the resulting image is perfectly correct.
Is there anything i can do to solve this problem?
Thanks in advance.
Luca.
Re: Incorrect image colors
Hello Luca,
Please try to use version 7.1 of VintaSoftTwain.NET SDK and let me know results.
Post by luca78mi »
Hello Alexander,
i tried the new version (7.1) but i still have the problem.
With a different computer running vista, same results.
Luca.
Hello Luca,
Please generate an advanced log-file and send it to support@vintasoft.com. Please scan small image when you will generate log-file and compress log-file before sending it to us.
Here is the snippet of code which allows you generate the extended log-file:
deviceManager.Logger = new DeviceManagerLogger(@"d:\vstwain.log", true);
deviceManager.Logger.LogInfoLevel = LogInfoLevel.Extended;
Hello Luca,
The problem is solved in version 7.1.2.
