Using VSTwain 4.4. Developing in C# using VS 2008.
I'm banging my head with this and can't find anything in the FAQ or forums. I'm sure I am missing something simple.
I want to set the Bit Depth to 8 in C#. Your examples are in VB, but it is fairly straight forward.
VSTwain1.OpenDataSource();
VSTwain1.PixelType = PixelType.RGB;
if (VSTwain1.IsCapSupported())
VSTwain1.Capability = (int)DeviceCapability.IBitDepth;
VSTwain1.CapType = CapType.OneValue;
VSTwain1.CapValue = 16;
VSTwain1.SetCap();
Couple of things. VSTwain1.Capability = DeviceCapability.IBitDepth; gives a compile time error Cannot implicitly convert type 'Vintasoft.Twain.DeviceCapability' to 'int'. An explicit conversion exists (are you missing a cast?)
But when I run the above code it errors at VSTwain1.SetCap(); Error to Set Capability value at Vintasoft.Twain.VSTwain.SetCap()
I'm not sure what I am doing wrong?
Thanks for the Help
