Our scanning application is crashing on the VSTwain1.Acquire(); function in 32-bit Windows 7. The scanner is a Xerox DocuMate 262. I am compiling the version 6 library.
Everything functions on Windows XP with that scanner. I have also scanned in 64-bit Windows 7 using a different scanner.
I'm now at a loss as to how to debug this problem. Does the VintaSoftTwain.NET library have a debugging log file I can enable?
if (debug)
MessageBox.Show("Acquiring...");
VSTwain1.Acquire();
catch (Exception em)
if (debug)
MessageBox.Show(em.ToString());
if (debug)
MessageBox.Show("finished");
I see the first MessageBox but not the second. No excepetion is thrown either. The program just crashes. I get the following errors in Windows event viewer:Faulting application name: ebillscan.exe, version: 1.0.3783.14170, time stamp: 0x4be96114 Faulting module name: KERNEL32.dll, version: 6.1.7600.16481, time stamp: 0x4b1e3897 Exception code: 0xc00000fd Fault offset: 0x0004f1f4 Faulting process id: 0x1650 Faulting application start time: 0x01caf111eb57121e Faulting application path: C:\ebillscan\ebillscan.exe Faulting module path: C:\Windows\system32\KERNEL32.dll Report Id: 3071847e-5d05-11df-a0ec-a4badbe64f0b
Fault bucket , type 0 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: P1: ebillscan.exe P2: 1.0.3783.14170 P3: 4be96114 P4: KERNEL32.dll P5: 6.1.7600.16481 P6: 4b1e3897 P7: c00000fd P8: 0004f1f4 P9: P10: Attached files: C:\Users\username\AppData\Local\Temp\WER5717.tmp.WERInternalMetadata.xml These files may be available here: C:\Users\username\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_ebillscan.exe_92ffddf1df9c13c67ba52bfe47de3a3065645af7_12f95c55 Analysis symbol: Rechecking for solution: 0 Report Id: 3071847e-5d05-11df-a0ec-a4badbe64f0b Report Status: 1Thanks!
Ryan
