Forum 'Announcements'
Version 12.1 of VintaSoft Imaging .NET SDK has been released.
Version 12.1.10.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that allows to edit values of interactive fields in PDF document.
Version 12.1.11.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that verifies PDF/A document.
Version 12.1.12.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in UserInteractionVisualTool and WpfUserInteractionVisualTool classes.
  • .NET development
    • Added new method - PdfPage.RemoveRotation, which rotates content of PDF page and sets PdfPage.Rotate property to 0.
    • Added new property - PdfPageRotateOrthogonallyCommand.UseRotateProperty, which rotates PDF page without changing of PdfPage.Rotate property.
Version 12.1.14.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in PdfPage.RotateContentOrthogonaly method.
Version 12.1.15.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in WpfPanTool visual tool. Now visual tool works correctly even when scrolls are disabled in WPF image viewer.
  • .NET development
    • Improved the algorithm that restores damaged PDF documents.
  • .NET development
    • Added the ability to change mouse cursors for actions in DicomViewerTool visual tool.
  • .NET development
    • Improved the algorithm that layouts elements in paragraph of DOCX document.
Version 12.1.16.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in PdfImageResource.SetImage method.
  • .NET development
    • Fixed the bug in the DicomViewerTool visual tool when tool is used in composition of visual tools.
Version 12.1.17.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that extracts text from document. Now algorithm provides better results for text with dropcap characters.
  • .NET development
    • Fixed the bug in algorithm that renders text symbol using graphic pattern.
Version 12.1.18.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm that detects rotation angle of image (GetRotationAngleCommand class).
  • Web development
    • Added WebImageViewerJS.set_ChangeFocusedImageWhenScrolling function, which allows to enable/disable changing of focused image in web image viewer while viewer scrolling.
  • .NET development
    • Added the ability to render the graphics pattern FreeFormGouraudShadedTriangleMesh.
Version 12.1.19.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Fixed the bug in algorithm that loads data of overlay image from DICOM file.
Version 12.1.20.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Added the ability to specify anchor for thumbnails in WinForms and WPF thumbnail viewer (ThumbnailViewer.ThumbnailsAnchor and WpfThumbnailViewer.ThumbnailsAnchor properties).
  • .NET development
    • Added the support for TrueType collections (TTC) in CID (Type0) fonts.
Page 2 from 3: 1 2 3
