Forum 'Announcements'
Version 8.7 of VintaSoft Imaging .NET SDK has been released.
Version 8.7.1.11 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in algorithm that renders PDF page.
  • Fixed the bug in class PdfDocumentBuilder.
  • Fixed the bug in algorithm that creates PDF form on PDF page.
Version 8.7.1.13 of VintaSoft Imaging .NET SDK has been released.
  • Improved the algorithm that generates warnings and errors in PDF.
  • Improved the algorithm that measures distance in DICOM image.
Version 8.7.1.15 of VintaSoft Imaging .NET SDK has been released.
  • Added new image print modes (FitToWidth and FitToHeight) in WinForms and WPF.
  • In the GetHistogramCommand class added the ability to get 16-bit histogram.
  • Fixed a minor bug in the WpfThumbnailViewer class - the WpfThumbnailViewer class did not raise the ThumbnailAdded and ThumbnailRemoved events when WpfThumbnailViewer.MasterViewer property was changed.
  • Improved the algorithm, which creates searchable PDF documents from OCR results.
  • Improved the algorithm, which draws text in PDF content - now algorithm takes into account information about font descent.
Version 8.7.1.17 of VintaSoft Imaging .NET SDK has been released.
  • Added the ability to add the user content to the thumbnail in WpfAnnotatedThumbnailViewer class.
  • Fixed the bug in algorithm that selects annotation in WPF annotation viewer while scrolling.
  • Fixed the bug in algorithm that draws annotation with color blending on thumbnails in WPF thumbnail viewer.
  • Fixed the bug in algorithm that parses PDF content.
  • Fixed a minor bug in algorithm that creates searchable PDF document from OCR results in PdfPageCreationMode.ImageOverText mode.
Version 8.7.2.1 of VintaSoft Imaging .NET SDK has been released.
  • View images in WinForms:
    • Added the ability to specify captions for thumbnails in thumbnail viewer.
    • Added the ability to specify the image padding of thumbnail in thumbnail viewer.
  • View images in WPF:
  • Demo applications:
    • WinForms and WPF demo applications have been added the ability to specify captions for thumbnails in thumbnail viewer.
    • WinForms and WPF demo applications have been added the ability to specify the image padding of thumbnail in thumbnail viewer.
  • The used Tesseract OCR engine has been updated to version 4.0:
    • improved the quality and performance of text recognition
    • extended the list of supported languages for recognition
  • Added the ability to recognize text in several languages using the functionality of Tesseract OCR engine. Previous versions allowed to recognize text in several languages using the SDK functionality.
  • OCR demo application has been added the ability to select several languages for text recognition.
Version 8.7.2.3 of VintaSoft Imaging .NET SDK has been released.
  • Fixed minor bug in algorithm that renders PDF page.
  • Some minor fixes.
Version 8.7.2.5 of VintaSoft Imaging .NET SDK has been released.
  • Added the WpfImageViewer.ImagePainted event, which occurs when the image is painted and visible in the viewer.
  • Improved the image rendering in WpfImageViewer and WpfThumbnailViewer when monitor uses not standard screen resolution.
  • Fixed the image zooming bug in WpfImageViewer when monitor uses not standard screen resolution.
  • Added new annotation ArcAnnotation (WinForms).
  • Changed behaviour of the line-based annotations - now annotation is not visible if length of annotation line is equal 0.
  • Optimized the drawing of WpfImageAnnotationView when annotation image is large.
  • In Annotation Demo added the ability to create ArcAnnotation.
  • Fixed minor bug in PdfDocumentCleanupCommand class.
  • Fixed minor bug in algorithm that removes PDF content.
  • Fixed minor bug in TesseractOCR.
  • Improved the DICOM decoder for compatibility with DICOM files with not correct metadata.
Version 8.7.2.7 of VintaSoft Imaging .NET SDK has been released.
  • Now Web API 2 controllers in Vintasoft.Imaging.Web.Api2Controllers.dll are compatible with ASP.NET Web API 5.2.7.
  • Fixed the bug in WpfImageViewer.ScrollToPoint method.
  • Added new annotation ArcAnnotation (WPF).
  • Now Web API 2 controllers in Vintasoft.Imaging.Annotation.Web.Api2Controllers.dll are compatible with ASP.NET Web API 5.2.7.
  • Fixed several bugs in builder and transformer of ArcAnnotation.
  • Now Web API 2 controllers in Vintasoft.Imaging.Pdf.Web.Api2Controllers.dll are compatible with ASP.NET Web API 5.2.7.
  • Fixed the bug in RemoveMarkedContentCommand class.
What's new in this version of VintaSoft Document Cleanup .NET Plug-in:
  • Now Web API 2 controllers in Vintasoft.Imaging.DocCleanup.Web.Api2Controllers.dll are compatible with ASP.NET Web API 5.2.7.
  • Tesseract4.Vintasoft.xXX.dll files were compiled using C++ compiler of Visual Studio 2017 and this allowed to increase the text recognition performance up to 30% in some cases.
  • Added the ability to calculate VOI LUT table of DICOM image with ignoring of extreme brightness.
  • In DicomViewerDemo/WpfDicomViewerDemo added a sample code, which shows how to draw the MPR cube axis in MPR 3D form.
  • In DicomViewerDemo fixed the bug in algorithm that saves DICOM annotations in PRE-file.
Version 8.7.2.9 of VintaSoft Imaging .NET SDK has been released.
  • The BorderClearCommand class binarizes source image for getting information about border pixels, which should be cleared. From this version the BorderClearCommand class allows to change and setup the binarization command, which is used for binarization of source image.
  • Now IsDocumentImageInvertedCommand class allows to specify what document type the user is looking for. Supported document types: document is received from scanner; document is received from photo camera.
  • Improved the algorithm that renders PDF content.
Version 8.7.2.11 of VintaSoft Imaging .NET SDK has been released.
  • Added the ability to process image region using the GetHistogramCommand class.
  • Improved the algorithm of IsDocumentImageInvertedCommand class.
What's new in this version of VintaSoft JBIG2 .NET Plug-in:
  • Fixed several bugs in JBIG2 decoder.
Page 2 from 3: 1 2 3
