Forum 'Announcements'
Version 8.4 of VintaSoft Imaging .NET SDK has been released.
Version 8.4.11.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed not critical bug in JPEG encoder.
  • Fixed a bug in renderer of CFF fonts.
Version 8.4.12.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in generator that generates the appearance of text interactive form fields.
  • Fixed the bug in coder of date-time values.
  • Fixed the bug in rendering of 8-bpp JPEG image in the Indexed->DeviceCMYK color space.
  • Now OCR engine can be used in multithreading environment.
  • Added the ability to get the text recognition result as a formatted text (OcrPage.GetFormattedText).
Version 8.4.13.1 of VintaSoft Imaging .NET SDK has been released.
  • Improved the rendering performance of PDF pages.
  • Improved the algorithm that extracts the formatted text from PDF page.
  • Improved the algorithm that creates the formatted text from OCR results.
Version 8.4.15.1 of VintaSoft Imaging .NET SDK has been released.
  • Improved the image caching in web image viewers.
  • Improved the algorithm that draws the line caps of annotations in HTML5 annotation viewer.
  • Some minor fixes in web image viewers.
Version 8.4.16.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in algorithm that draws the Highlight annotation.
  • Improved the algorithm that searches the external fonts of PDF document.
  • Fixed the minor bug in algorithm that renders layers (optional content) of PDF document.
Version 8.4.17.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in algorithm that draws the Highlight annotation in the annotation group.
  • Added new class PdfInteractiveFormVintasoftBarcodeField, which allows to add the interactive field with 1D or 2D barcode to a PDF document. New interactive field can use any 1D or 2D barcode symbology available in VintaSoft Barcode .NET SDK. New field will be visible in any PDF viewer, editing of new field is available only in Vintasoft PDF viewer. Standard interactive field with barcode (the PdfInteractiveFormBarcodeField class) allows to use only QR, DataMatrix and PDF417 barcodes.
  • Fixed a minor bug in algorithm that generates an appearance for PDF text annotation.
  • Fixed the bug in algorithm that draws the transparent PDF content.
Version 8.4.18.1 of VintaSoft Imaging .NET SDK has been released.
  • Now SDK can create TIFF files, which are compatible with “legacy” TIFF viewers.
  • Added the ability to use text wrapping in the PDF interactive form text field (PdfInteractiveFormTextField).
  • Fixed the bug in algorithm that renders transparent content on PDF page.
Page 2 from 2: 1 2
