Forum 'Announcements'
Version 6.1 of VintaSoftImaging.NET SDK has been released.
Version 6.1.7.1 of VintaSoftImaging.NET SDK has been released.
  • Added support for image-resources with soft-mask that contains premultiplied alpha.
  • Fixed the bug in the rendering algorithm of PDF page appearance when Tiling Pattern is used for filling out the graphics path.
What's new in this version of VintaSoftOCR.NET Plug-in:
  • Fixed the bug that caused the PinvokeStackImbalance exception if Vintasoft.Ocr.Tesseract.dll is used in Visual Studio (2010/2012) with enabled MDA.
Version 6.1.8.1 of VintaSoftImaging.NET SDK has been released.
  • Optimized the performance of image processing commands: DilateCommand, ErodeCommand, MinimumCommand and MaximumCommand.
  • Fixed the bug in ImageAnnotationBase class.
  • Fixed problem with character encoding in TTF font.
  • Fixed problem with character width in CFF font which caused character misalignment.
  • Fixed problem with character size in CFF font which caused character misalignment.
Version 6.1.9.1 of VintaSoftImaging.NET SDK has been released.
  • Fixed the bug in image viewer which caused disabling of dynamic rendering of vector image (PDF page).
  • Optimized the rendering speed and quality of HighlightAnnotation.
  • Optimized the image extraction from PDF page, now ImageExtractor can extract images which are drawn with TilingPattern.
  • Optimized and improved the text extraction from PDF page.
Version 6.1.10.1 of VintaSoftImaging.NET SDK has been released.
  • Added the ability to manage existing optional content (layers) of PDF document.
  • Increased the performance of PDF page rendering.
  • Improved the text extraction from PDF page.
  • Fixed problem with character encoding which caused the wrong result of text extraction.
  • In Pdf Reader Demo added the ability to manage layers (optional content) of PDF document.
Version 6.1.12.1 of VintaSoftImaging.NET SDK has been released.
  • Now the InvertCommand class inverts image data, previous version inverted the image palette and did not change the image data.
  • InvertCommand class now can process region of the black-white image.
  • Rendering speed of PDF page is increased for pages which contain many small JPEG images.
  • Fixed the bug in algorithm of text extraction.
  • Fixed bug in the image preprocessing algorith for black-white images with inverted palette.
Version 6.1.13.1 of VintaSoftImaging.NET SDK has been released.
  • Improved the algorithm of Type1 font parser.
  • Improved the rendering algorithm of symbols from Type1 fonts.
  • Fixed the freezing of PDF decoder when opening PDF document from a stream with length less than 13 bytes.
  • Fixed the bug in determining of palette for black-and-white images with non standard parameters of color space.
Version 6.1.14.1 of VintaSoftImaging.NET SDK has been released.
  • Added read-write support for JPEG2000 compression in TIFF files.
  • Improved the image printing algorithm. Now physical margin of page is used when image is printed.
Version 6.1.14.5 of VintaSoftImaging.NET SDK has been released.
  • Added ability to render TIFF files with JPEG2000 compression.
  • Improved the algorithm of JPEG decoder for better compatibility with Windows XP.
Version 6.1.15.1 of VintaSoftImaging.NET SDK has been released.
  • Added the ability to decode image compressed with CCITT3 2D algorithm. Improved CCITT3 decoder.
  • Added the ability to decode image in DeviceN color space with 2 and more channels.
  • Improved the algorithm of PDF Type0 function (SampledFunction).
  • Fixed the bug in parser of inline-images with RunLength compression.
Version 6.1.16.1 of VintaSoftImaging.NET SDK has been released.
  • Fixed critical bug in JPEG encoder.
  • Fixed not critical memory leak in ImageViewerBase class. Memory leak occurs after destroying of ImageViewer which was never visible.
  • Increased speed and improved quality of ShadingPattern rendering.
  • Fixed the bug in rendering of ShadingPattern which caused freezing of application.
  • Fixed the bug in parser of inline-images with ASCII85 filter.
Page 2 from 3: 1 2 3
