Imports System.IO
Imports Vintasoft.Imaging
Module Module1
Sub Main()
Using jpegStream As FileStream = New FileStream("..\..\Exif.jpg", FileMode.Open, FileAccess.Read)
Using jpeg As JpegFile = New JpegFile(jpegStream)
If exif Is Nothing Then
Console.WriteLine("JPEG file does not have EXIF data.")
Else
WriteTagsData("EXIF", exif.ExifTags)
WriteTagsData("GPS", exif.GpsTags)
End Using
End Using
Console.WriteLine("Press any key to continue...")
Console.ReadKey()
End Sub
Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection)
If tags.Count = 0 Then
Console.WriteLine(String.Format("No {0} data.", tagsName))
Else
Console.WriteLine(String.Format("{0} data [{1}]:", tagsName, tags.Count))
For i = 0 To tags.Count - 1
Console.WriteLine(String.Format("- {0}", tags(i)))
Next
Console.WriteLine()
End Sub
End Module
Imports System.IO
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Using jpegStream As FileStream = New FileStream("..\..\geotag005.jpg", FileMode.Open, FileAccess.Read)
TextBox1.Text = "JPEG file does not have EXIF data."
Else
End Using
End Using
End Sub
Public Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection)
TextBox1.Text = String.Format("No {0} data.", tagsName)
Else
TextBox1.Text = String.Format("{0} data [{1}]:", tagsName, tags.Count)
TextBox1.Text = String.Format("- {0}", tags(i)) & vbCrLf
Next
End Sub
Else
End Using
End Using
End Sub
Private Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection)
TextBox1.Text = TextBox1.Text + String.Format("No {0} data.", tagsName) & vbCrLf
Else
TextBox1.Text = TextBox1.Text + String.Format("{0} data [{1}]:", tagsName, tags.Count) & vbCrLf
Dim tag As TiffTag
tag = tags(i)
TextBox1.Text = TextBox1.Text + String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.Name, tag.Id, tag.Type, tag.Data) & vbCrLf
Next
TextBox1.Text = TextBox1.Text + vbCrLf
End Sub
Else
Dim tag As TiffTag
Dim tagData As Object
Dim tagDataAsArray As Array
Dim tagDataAsString As String
' for each tag in tag collection
' get tag
tag = tags(i)
' get tag data
tagData = tag.Data
' if tag data is array
If IsArray(tagData) Then
tagDataAsString = "[ "
tagDataAsArray = CType(tagData, Array)
For j = 0 To tagDataAsArray.Length - 1
tagDataAsString = tagDataAsString + tagDataAsArray(j).ToString + "; "
Next
tagDataAsString = tagDataAsString + "]"
' if tag data is NOT array
Else
tagDataAsString = tagData.ToString()
' add information about tag to textbox
TextBox1.Text = TextBox1.Text + String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.Name, tag.Id, tag.Type, tagDataAsString) & vbCrLf
Next
End Sub
Else
WriteTagsData("EXIF", exif.ExifTags, GetType(ExifTagId))
WriteTagsData("GPS", exif.GpsTags, GetType(GpsTagId))
End Using
End Using
End Sub
Private Sub WriteTagsData(ByRef tagsName As String, ByRef tags As TiffTagCollection, ByRef tagIdEnumType As Type)
Else
Dim tag As TiffTag
' get tag
tag = tags(i)
' get tag data
tagData = tag.Data
Next
Else
TextBox1.Text = TextBox1.Text + String.Format("- Name={0}, Id={1}, Type={2}, Data={3}", tag.GetName(tagIdEnumType), tag.Id, tag.Type, tagDataAsString) & vbCrLf
Next
End Sub
